There seems to be some misinformation about the necessity for Activesync on your machine before installing Planmaker in this review:
http://spreadsheet-software-review.topt ... eview.html
I think this requirement is only for window mobile versions of Planmaker?
(EDIT: Actually having read through some of the other reviews of spreadsheets in this comparative review of spreadsheet software
http://www.squidoo.com/spreadsheet-software-review
I think the reviews are shallow and have a lot of mistakes. Ah well.)
Lance
Misinformation in a review
- Contact:
Re: Misinformation in a review
Well, send them an e-mail pointing out their errors. Maybe you have more luck than we had. We sent them an e-mail listing the errors they made in a review of TextMaker, and they never fixed these errors. It seems they don't listen or don't care.
Ha - I'm sure if you couldn't move them then I won't be able to.
Cheers
Lance
Cheers
Lance
