"Printing" to PDF Questions
I self-publish books through Amazon KDP. The preferred upload to Amazon is a PDF with fonts embedded.
I just tried to create a PDF from a third-party program (app) using the FlexiPDF virtual printer. The page size of the document is 6 inches by 9 inches (a standard book size in the U.S.). FlexiPDF put the document in the correct type size, but on 8-1/2-incj by 11-inch pages. How do I set the correct page size in FlexiPDF?
Also, there was nothing to indicate whether or not fonts are being embedded. Obviously, my system has the fonts I use already installed, but how can I verify that the fonts are embedded in case Amazon's system doesn't have one or more of the fonts I use? (Which would be likely, since I have Megafont NOW and I use some of those fonts in my books.)
Re: "Printing" to PDF Questions
Post by Jossi »
If FlexiPDF's virtual printer doesn't meet all your needs, you could try eDocPrintPro (https://www.pdfprinter.at/en/). This is a free, highly flexible virtual printer which allows you to embed fonts and define page sizes. It hasn't let me down yet.
I have doPDF, but since I bought FlexiPDF I would really like it if it would do what needs to be done.
On the page size issue: I went through the exercise of creating a custom page size. It didn't work. I set the page size for 6" x 9", and it created am image of the text formatted as it should appear on a 6" x 9" page -- but on an 8-1/2" x 11" page.
Frustrating.
