Are you planning any integration with any open source content management systems or portal servers to accomodate easy publishing of SoftMaker office documents? For example, assume that I wrote a blog or such content in TextMaker, and assume that there is a publish button. My configuration is set to point my internal or external webdav or such server. When I click to publish button, it gets published to web or intranet or document workspace or as direct content.
Thanks.
SoftMaker office server
I was checking the most used ones as CMS systems. I personally use Joomla and I am quite happy about it. However, there is a review of all ones in this link, if you may want to consider another one.
http://www.packtpub.com/article/open-so ... -announced
Corel® WordPerfect® Lightning
Corel® WordPerfect® Lightning implements similar concept what I recommended to you.
http://www.corel.com/servlet/Satellite/ ... 1405162003
