It seems there is no keyboard shortcut to paste as values. In most spreadsheets (Excel, Numbers, LibreOffice, OnlyOffice), this is Shift + Ctrl + V.
Not having this as a standard shortcut in PlanMaker is driving me crazy because I use it all the time in those other spreadsheets.
Is there a way to define it as a custom keyboard shortcut?
Past as values keyboard shortcut?
Re: Past as values keyboard shortcut?
Thank you for reporting your issue.
Yes, this functionality is not available in FreeOffice PlanMaker. However, it works correctly in the commercial version, where you can also configure your own keyboard shortcuts.
RussellM72
Ok. Thanks for the reply.
Based on that info, I installed the free trial of PlanMaker NX and when I try Shift + Ctrl + V (this is on Fedora KDE), nothing happens.
Just poking around in Options and Customize, I'm not seeing where to define custom keyboard shortcuts.
