SOLVED page size metric
WacoJohn
Post by WacoJohn »
Flexipdf 2025 v 2025 416 1204 64bit
Newcomer to forum. Enjoying Flexipdf 2025. Just noticed page size is in centimeters for Welcome-EN.pdf I don't see any 'preferences' for metric or Imperial. Maybe it is per construction of the file on display the Welcome.pdf was constructed to measure in metric or is that not selectable? Is the product strictly metric?? Thanks in advance. Happy Holidays to all. 🎅
ITFlip
Re: page size metric
Post by ITFlip »
Hello,
Unit preferences can be set in the following location: File menu, Options, Editing section, Unit of Measure.
There are 5 options: Inches, Centimeters, Millimeters, Points, Picas
The margins of a document that you open are determined by the margins used when it was created.
WacoJohn
Post by WacoJohn »
Thank you for the quick and friendly reply. Best holiday wishes to you and yours.
