Next slide automatic don't work
pat.corret
Post by pat.corret »
Hello,
When I select "Slide Transition" and then "Automatic Next Slide" after 00:02, for example, the slideshow doesn't advance automatically; it only changes if I press the spacebar to advance the slide.
Any ideas?
Re: Next slide automatic don't work
Thank you for posting your problem, but I am unable to reproduce it.
Please share the file in which you are getting this issue so that we can check at our end.
Return to “FreeOffice Presentations 2024 for Windows”
