insert a line break in a cell - Alt+Enter doesn't work
karibou79
Post by karibou79 »
I want to insert a line break in a cell, but Alt+Enter doesn't work. I'm using Windows and the Alt key on my keyboard is working fine.
Is there another shortcut?
Thanks for your help.
lgsl
Re: insert a line break in a cell - Alt+Enter doesn't work
Post by lgsl »
Try Ctrl+Enter
karibou79
Post by karibou79 »
It works, many thanks =D>
It sounds simple but I didn't find this workaround anywhere.
stascheit
Post by stascheit »
You can find it here in this chapter of the manual:
https://help.softmaker.com/planmaker202 ... nment.html
Another tip: All relevant shortcuts are also listed in the appendix:
https://help.softmaker.com/planmaker202 ... sions.html
