Update at the End of October removed ability to save as Open Document Spreadsheet
economistbob
Post by economistbob »
It seems the update at the end of October removed the ability to save as Open Document Spreadsheet, ODS. There is no mention of this on any release notes. I tried with different documents and rebooting the machine. ODS no longer appears in the "Save As" list.
Re: Update at the End of October removed ability to save as Open Document Spreadsheet
Thank you for your suggestion. The ODS format is not currently available in the “Save As” list because PlanMaker does not support exporting to that format. However, I have forwarded your request as an improvement suggestion.
