Annoying nag screen when opening
I'm still using FlexiPDF Professional 2022. The new features in 2025 aren't enough to make it worth the time and expense of upgrading eight computers.
The problem: EVERY time I start FlexiPDF, I am greeted by a nag screen that says there is an updated version available, and it asks me if I want to download and install the update. If I click "Yes" to accept the update ... I then get a screen telling me that I already have the latest version of FlexiPDF 2022, but that I can update to FlexiPDF 2025.
This is annoying. There should be some way to banish that notice permanently.
Re: Annoying nag screen when opening
There is. Click "Skip this update".
martin-k wrote: Sat Oct 25, 2025 9:31 pm There is. Click "Skip this update".
I do that ... every time the prompt appears. And the next time I start FlexiPDF, the prompt reappears.
raitis.veksejs
Post by raitis.veksejs »
If you run the app twice in a row as admin (right-click the FlexiPDF.exe file and select "Run as admin"), does the "A newer version is available" prompt still appear?
Based on my testing, the flag is stored in a registry entry under "Computer\HKEY_CURRENT_USER\Software\SoftMaker\FlexiPDF."
If FlexiPDF cannot read or write the flag, that would explain the prompt reappearing. Insufficient Windows permissions or aggressive third-party security software can cause this. With default settings, there should be no issues.
You can also try reinstalling the app to see if that helps.
Thank you. I will investigate further ...
