View: Two Pages or Book Layout
doubledutch
Post by doubledutch »
Hello,
I have just updated to Flexi PDF 2025 and have two small questions:
- I would like to have "Two Pages" at 100% as my standard view. It looks as if this is not possible. Whenever I open a file, it automatically shows 154% or so, which means that I can only see a part of the page. Ideally, I would like to see a spread of two pages, not more, not less. I also tried "Book Settings" but that does not work either. Is there an option that I overlooked?
- Is there a way to browse through a PDF file just using the space bar? This is much more convenient than using the arrow key.
Otherwise, your programme is just fine!
Many thanks.
raitis.veksejs
Re: View: Two Pages or Book Layout
Post by raitis.veksejs »
#1 You can set the zoom for an individual document or globally under "File > Options > Loading," there you have the following options:
- Default Zoom
- Initial View
Both can be set to "Fit two pages"
#2 You can't change pages by pressing "Space" like you can in Adobe Acrobat. I forwarded your feature request to our developers.
