Touchpad and Touchscreen Scrolling
jamesmadison
Post by jamesmadison »
Scrolling with the touchpad is not smooth, instead jumping 3 lines at a time as if it were being scrolled with a scroll wheel. Scrolling with touchscreen does not work, and instead selects text. I am on wayland. Can you fix scrolling on linux to make it smooth?
Re: Touchpad and Touchscreen Scrolling
For the best stability, we recommend using X11. The Wayland display server is still evolving and may have compatibility issues that could cause the problem you're experiencing.
