Equivalent to Excel Shortcut Ctrl+[
moneillqs
Post by moneillqs »
In excel I constantly use Ctrl+[ shortcut to go to a cell in another worksheet which is referred to in the current cell.
In Planmaker, I can use TracePredecessor to show Predecessor, but then I have to mouse click on a little circle to to go to the actual predecessor cell. How can I do this using a single shortcut key combination like Ctl+[
Re: Equivalent to Excel Shortcut Ctrl+[
Thank you for posting your query. You can add this shortcut key for command “Trace Predecessor” by using “customize ribbon” feature.
