textmaker, planmaker and presentation files won't open 2024 for windows
cpa
Post by cpa »
I have been using it since long time and suddenly, Windows freeoffice 2024 (textmaker, planmaker and presentation) files won't open.
If I remove/uninstall .exe then install again I am able to open files for 2 or 3 times, then it would crash next day it won't open, If I reinstall it would work.
I try repairing, that didn't work.
I tried running as admin, that didn't work either.
So, I try to run those service pack and I got error again.
Re: textmaker, planmaker and presentation files won't open 2024 for windows
Is this issue specific to our software, or are you experiencing it with other applications as well?
Since it was working before, the cause might be external. We recommend checking for system file corruption and ensuring no malware is present, as these can often affect software performance.
