How to stop force switching windows
Faust
Post by Faust »
Whenever I'm going back-and-forth between SoftMaker office apps and any other app, like browser or whatever, a SoftMaker app will forcibly switch to its own window. The only way to make it stay on the background is to specifically use window's minimising function.
It pisses me off so much I'm on the verge of deleting SoftMaker apps altogether.
Faust
Re: How to stop force switching windows
Post by Faust »
Anyone?
Please click on ribbon command File | Options | tab Appearance | Uncheck the option “Show tooltips” | OK.
This seems an operating system level issue. Disabling tooltips will most probably resolve this issue for you.
Faust
Post by Faust »
Thanks, unchecked them.
Weirdly enough, for the first time in several years I have Softmakers Office - it wasn't switching while I was looking into you instructions step by step.
What a coincidence!! Nevertheless, I did what you told me and I will test it some more. Thank you!!!
Faust
Post by Faust »
Looks that this behaviour has stopped. Thank you again. This thread can be closed.
