Product key
GeorgeKaplan
Product key
Post by GeorgeKaplan »
I'm struggling to get a product key because it says "cannot connect to server". Any ideas? Clearly I have wi fi that's how I downloaded the programme.I have cleared the cache but no luck. Help appreciated.
Re: Product key
SuperTech wrote: Sat Aug 23, 2025 7:40 pm It appears that your FreeOffice software is unable to access the internet. This is often caused by security settings on your computer. To help resolve this, please try the following steps:
1. Check Security Software: Temporarily disable your antivirus or firewall to see if it is blocking FreeOffice. Remember to re-enable it afterward.
2. Proxy Settings: If you use a proxy server, try disabling it temporarily to test the connection.
3. Malware Scan: Run a full system scan to ensure your computer is free from malware, which can sometimes interfere with internet access.
ImranIffco
Re: Product key
Post by ImranIffco »
I had also same problem with Retry server connection.
plz help to to sort out this pblm
Re: Product key
Please apply the troubleshooting steps outlined above.
