Textmaker S1225.0805.998 crashes when opening files
JLDP
Post by JLDP »
I'm using Textmaker on two Android tablets, where it has recently updated to the latest version (1225.0805 dated 4 August 2025). Since that update, I have encountered a major problem. It will not open larger .docx files which were created with Textmaker on Linux - a blank page opens, there may be a progress bar (depending on size of the file) and it then crashes. It does open small files (less than about 50k) and it will open .docx files created in Microsoft Word or created on the tablet, but not those imported from my main computer (running TextMaker Professional 2024 (rev S1224.0308) 64bit under ZorinOS).
This occurs on a Lenovo Tab M8 (4th gen) TB300FU running Android 13, and on a Honor Pad 9 running MagicOS 8 (Android 14).
I have reverted to the previous version (1223.0202) which opens these files without difficulty, and turned off auto-update of apps.
JLDP
Re: Textmaker S1225.0805.998 crashes when opening files
Thank you for bringing this issue to our attention. To help us investigate further, could you please share the file where you're experiencing this problem? This allows our team to examine it directly and provide a more accurate solution.
If your file is large, as you mentioned, we recommend uploading it to a cloud storage service (such as Google Drive, Dropbox, or OneDrive) and sharing the download link with us.
If the file contains sensitive or private information, please send the download link directly to forum[at]softmaker.com and include a reference to this forum post for context.
JLDP
Post by JLDP »
Thank you for your reply. I encountered this problem with several current files, the attached is one example.
Regards
JLDP
Consolidated list of faculties Bucks 1785-1982 (by church) WIP.docx
(316.25 KiB) Downloaded 3801 times
Thank you for providing the sample file. I have successfully reproduced the issue and have escalated it, along with all relevant details, to our development team for a thorough investigation.
Return to “TextMaker NX for Android”
