In the process of installing the update for SoftMaker Office on Android, I discovered that I have SoftMaker Office installed on only one of three tablets. When I try to install it on the other two, searching the Google Play Store doesn't return any hits. I assume this is because they are so old that their operating systems won't support the current version of SoftMaker Office. (One device is on Android 5.1.1, the other is on Android 7.0. They can't be updated beyond that.)
I woukld like to have SoftMaker Office on these other two tablets. Is there a way to manually download and install the last version that will run under these older versions of Android?
Older versions available?
Re: Older versions available?
Never mind!
Just color me stupid. I thought I had installed SoftMaker Office on all three tablets, and I was correct. On the older ones, they don't show up in "Manage Apps & Device," most likely because they are an older version and the update can't be installed on them. But I do have SoftMaker Office on the older tablets. Problem solved.
Sorry for the false alarm.
- SoftMaker Office 2021
