August 2025 update
August 2025 update
I just received an e-mail notification that there's an update available. In the e-mail, it says, "You can also check for updates manually by choosing the menu command My Apps in the Google Play Store."
My devices are Samsung tablets. There is no "My Apps" menu command. In the Play Store, when I click on my glyph to access my account, there is an option for "Manage apps & device." I can manually check for and install updates from that.
It's the same for three different Samsung tablets, each running different versions of Android.
