Rendering problem with fading graphics
GuernseyMan
Post by GuernseyMan »
I have a number of books which have a gradient transparency on one edge of the each page. When I use other readers (Foxit, Adobe etc) it renders correctly:
When I use FlexiDPF 2025 (both 32bit and 64bit versions the transparency is not rendered properly, the graphic shows completely opaque:
The physical book has the fading so I'm sure that's how the PDF is supposed to render. I've attached a sample page from the book so you can see how the author has set the graphic up.
Book sample.pdf
(125.75 KiB) Downloaded 3949 times
Re: Rendering problem with fading graphics
Thank you for providing the sample file and screenshots. I've successfully reproduced the issue and have forwarded all relevant details for further investigation.
