Macro for Textmaker
mne.webmaster
Macro for Textmaker
Post by mne.webmaster »
Good morning, since Textmaker doesn't have the ability to automatically adjust the width of table columns, I'm wondering if it's possible to create a macro for this purpose. Thanks.
Re: Macro for Textmaker
No, FreeOffice doesn't have BasicMaker application using which you can create VBA-like macros.
Only the commercial versions have that application.
mne.webmaster
Thank you. So, this option is available for the commercial version. If I need help, can I ask for help creating a macro that performs the function I'm looking for? Since I install operating systems and specific programs upon request, I'll try to contact a customer who has the commercial version of Softmaker and, if possible, ask them to contact you. Thank you.
Return to “FreeOffice TextMaker 2024 for Windows”
