space between words
Floris
space between words
Post by Floris »
When I type a space is it not working only also whit the option key, what can I do ?
Re: space between words
Post by Jossi »
Does this only happen in TextMaker? Are you sure that the space key on your keyboard is working properly?
Floris
Post by Floris »
Yes, I have the TextMaker on a windows computer and its working perfect, when I reply also with the Mac in this answer is no problem .
Its only when I use Textmaker on the Mac.
Regards Floris
Please reinstall SoftMaker Office on your Mac with the latest download from our website and then check.
Floris
Post by Floris »
Sorry I renew the installation but it is still the same
Floris
To ensure a clean reinstallation, could you please confirm if you:
1. Uninstalled the previous version
2. Restarted your system
3. Downloaded the latest installer from our website
4. Performed a fresh installation
If you’re still experiencing issues, we recommend this additional step:
1. Close all SoftMaker applications
2. Rename the /Documents/SoftMaker folder (e.g., to “SoftMaker_Old”)
3. Restart the software to generate fresh configuration files
Please let us know if the issue persists after trying these steps.
Return to “TextMaker NX and 2024 for Mac”
