Comment numbering
enonod
Comment numbering
Post by enonod »
Textmaker Pro 2024 (rev S1224.0308) 64bit ARM
After setting comments visible so they show at the side of the page with arrows to the highlighted text...
If I have some comments already done, then insert another to the left of the existing one, the comments renumber perfectly (the little number in each comment box).
If I now delete that last added comment, the others do not (un) renumber.
Re: Comment numbering
Thank you for reporting this problem. Our team has been unable to reproduce the issue in our testing environment.
To help us investigate this further, could you please provide the following:
  • The specific file in which you encounter the problem.
  • A detailed list of the steps you take that lead to the error.
If the file contains sensitive information, please send it directly to forum[at]softmaker.com and include a link to this post for reference.
enonod
Post by enonod »
I apologise for the delay, a memory problem!
I tried this again on a clean document and it worked perfectly.
I have no idea what was wrong. Clearly it is not a bug.
Sorry for the wasted tests you did.
Return to “TextMaker NX and 2024 for Mac”
