Persisting Issues with copying Conditional Formatting
ozboomer
Post by ozboomer »
See https://forum.softmaker.com/viewtopic.php?t=23690
I tried a similar operation where a cell had multiple rules... and when the cell was copied ('completely' with 'Paste' or with 'Paste Special' for only 'Conditional Formatting') the order of the rules was mixed-up.
However, if I select the entire row where the cell with conditional formatting is present (via clicking on the row number at the left of the worksheet), copy it (CTRL-C) and then move to another row.. and use Ribbon > Cells > Insert > Insert copied cells... the order of the conditional formatting rules in the relevant cell is maintained. Edit: Doesn't always work. With 3 rules or more, the order of the first two are mixed up.
Using PlanMaker 2024 (rev S1224.0308) 64bit under Windows 11 Home.
Re: Persisting Issues with copying Conditional Formatting
Thank you for reporting this issue. I have forwarded the details for further investigation.
