BasicMaker Editor now has tiny fonts? [SOLVED with Warnings]
ozboomer
Post by ozboomer »
Hi, all...
I've just opened BasicMaker to try and deal with some code... and for some reason, the font size in the editor has become minuscule, viz:-
The File > View > Customize settings haven't been changed, viz:-
Changing the font values doesn't alter the way the editor looks.
It's been working Ok for ages.... but maybe it's related to a recent Windows update? Recent Windows Updates have been:-
  • 2025-07 Cumulative Update for Windows 11 Version 24H2 for x64-based Systems (KB5062553) (applied 9-JUL-2025)
  • 2025-07 Cumulative Update for .NET Framework 3.5 and 4.8.1 for Windows 11, version 24H2 for x64 (KB5056579) (applied 9-JUL-2025)
As it is, BasicMaker is unusable, as I can't read the code, any watch windows, etc.
I'm using BasicMaker Professional 2024 (rev S1224.0308) 64bit under Windows 11 Home, 64-bit.
Any suggestions on how this problem might be resolved?
Thanks.
Re: BasicMaker Editor now has tiny fonts?
Select a functioning printer driver in File | Print. The "Generic / Text only" driver is unusable.
ozboomer
Post by ozboomer »
martin-k wrote: Sat Jul 12, 2025 3:32 pm Select a functioning printer driver in File | Print. The "Generic / Text only" driver is unusable.
Pretty weird design 'feature' that a Printer setting should affect the User Interface... although, those limited available fonts were definitely a clue.
A drastic solution... but sometimes y'just have t'do what you need to, I guess...
File > Options > View > Manage > Reset
...all settings.. default values... : YES
...restart BasicMaker... : YES
...User Interface settings (as required) : OK
File > Options > View:
...and the editor looks Ok... but 'tis still curious how it changed... Maybe it WAS as simple as changing the printer somewhere else updated the 'system default' (I guess).
ozboomer
Post by ozboomer »
Just to note... the 'reset' seems to reset the suite.. as I needed to enter personal info into Textmaker again... and Planmaker had some different defaults.
FYI...
