FreePDF 2025 install error
goldermann@gmail.com
Post by goldermann@gmail.com »
trying to install FreePDF 2025.It installs but when I launch it, it has and error 2. cannot locate specified file. I redownloaded it and installed again. same error. I tried to install to a different location. Still the same error. can anyone assist in a solution?
Re: FreePDF 2025 install error
To help us better diagnose the issue you're experiencing, could you please share a screenshot of the error message you're encountering.
Try downloading the file using a different web browser (e.g., Chrome, Firefox, Edge) to see if the issue persists.
Please also check:
  • Are you logged in with full administrator rights on your computer?
  • Which antivirus/security software are you currently using?
  • Did you receive any security alerts or blocks during the installation process?
Return to “FreePDF 2025 for Windows”
