BUG: Install returns "file not found"
Darc Sceptor
Post by Darc Sceptor »
I am running Bazzite Linux. I downloaded the RPM file. I doubleclicked the file, I right-clicked and Open File with Discover and in both cases I got a failure to open due to a missing file.
lgsl
Re: BUG: Install returns "file not found"
Post by lgsl »
Install it using the package manager via a terminal, not an UI like discover to know what the problem really is.
Michael Uplawski
Post by Michael Uplawski »
Darc Sceptor wrote: Mon Jun 30, 2025 12:39 am I am running Bazzite Linux. I downloaded the RPM file. I doubleclicked the file, I right-clicked and Open File with Discover and in both cases I got a failure to open due to a missing file.
PSE report *which* file has been found missing.
Apart from that, installations on Linux happen in diverse ways, but only very exceptionally by clicking on anything. An RPM file is meant for a package manager to open or for a tool that is explicitly started on a command line. Have you installed other software from an RPM file before? I bet not.
There are flatworlders all around the globe. (unknown author)
If we go now, nature may stand a chance. (known author)
lgsl
Post by lgsl »
Bazzlite is simply a themed Fedora. This is why it makes me think is a Discover/PackageKit issue and why he should install SMO using dnf. If the rpm is corrupted or something then we will know. Those UI's, like Discover usually, when there is an issue with the package simply give a generic error message. Perhaps is PackageKit's doing or the way this «App Stores» wannabees work.
