Thumbnail view pane - icon contomization & page organization
iieeann
Post by iieeann »
Hi,
As topic. The page rotation is only 1 way which is troublesome to use, some icons i will never use and i don't want it to be there.
Is there a whole page thumbnail view? current thumbnail pane is inefficient to use to organize pdf with many pages. How to multi-select the page to be rotated or deleted? I came from Acrobat and found that flexiPDF is very inefficient in organizing large pdf.
The speed of thumbnail rendering is very slow and the most annoying part is it will re-render everytime the panel size is changed, this is not productive at all.
Thsnks.
Re: Thumbnail view pane - icon contomization & page organization
Thank you for posting your queries.
iieeann wrote: Tue Jun 24, 2025 5:26 am The page rotation is only 1 way which is troublesome to use,
We have both clockwise and Anticlockwise page rotation available. Please check again.
iieeann wrote: Tue Jun 24, 2025 5:26 am some icons i will never use and i don't want it to be there.
Currently, such customization is not available.
iieeann wrote: Tue Jun 24, 2025 5:26 am Is there a whole page thumbnail view? current thumbnail pane is inefficient to use to organize pdf with many pages.
Please share complete details of this issue. You can expand the pane as per requirements.
iieeann wrote: Tue Jun 24, 2025 5:26 am How to multi-select the page to be rotated or deleted? I came from Acrobat and found that flexiPDF is very inefficient in organizing large pdf.
To rotate multiple pages, you can select All or the page range from to, which is the easiest way.
Similarly, To delete multiple pages, you can select All or the page range from to, additionally, you can apply even/ odd filter also in your selection.
iieeann wrote: Tue Jun 24, 2025 5:26 am The speed of thumbnail rendering is very slow and the most annoying part is it will re-render everytime the panel size is changed, this is not productive at all.
We are unable to reproduce this issue, so please share your problematic file and screen recording for better understanding. Also, performance is dependent on system processing capacity also.
iieeann
Post by iieeann »
No, i only see anticlockwise icon. If i need to make few more click to see the clockwise rotation, this will be too troublesome.
the left side panel, even i enlarge the side panel, the page view only become bigger, not more pages. i need a page that can show all pages so that easy to select which page to rotate or delete.
No way i can select easily which page to rotate or delete. for example the 10 pages pdf i attach, if i want to select page 1,4,8,9 to rotate, how to do? Your program can't even show all the 10 pages at once in thumbnail for multi selection. Don't tell me i need to slowly navigate to the page and delete 1 page by 1 page. Similarly how to rotate those specific pages
I am referring to the thumbnails tab on the left panel. Everytime the panel is resized, the thumbnail content will need 3-4 seconds to show again. This is very unproductive, why can't the content scale smoothly following the panel resizing?
dummy_10_pages.pdf
(5.63 KiB) Downloaded 4114 times
