I'm using SoftMaker Office 2024 on Fedora Linux Workstation 41, and I recently noticed that I can't zoom in on documents using the touchpad gesture. This works in Google Chrome/Chromium after changing chrome://flags/#ozone-platform-hint to Wayland. I reported this issue to support[at]softmaker.com, but they could not reproduce it.
Is anyone else having the same issue?
Zoom with touchpad gesture
sergiuvolda
Fedora Linux Workstation 42
Former Manjaro and Ubuntu user.
Re: Zoom with touchpad gesture
Thank you for posting your issue. Based on your description, we'd like to clarify that touchpad gestures are primarily managed at the operating system level. As you mentioned on third party software like chrome also, it was originally not working without changes.
You can check it if it's working with X11 or not.
sergiuvolda
Nope. The touchpad gesture to zoom in both Chromium and SoftMaker Office doesn't work when switching to X11. However, as I previously mentioned, the touchpad zoom gesture in Chromium could work in Wayland if Chromium is set to run in Wayland with chrome://flags/#ozone-platform-hint. Unfortunately, this still doesn't work for SoftMaker Office.
Could this be considered a bug?
Unfortunately, we can't do anything here as this is handled on operating system level.SuperTech wrote: Wed Jun 25, 2025 9:21 pm Based on your description, we'd like to clarify that touchpad gestures are primarily managed at the operating system level. As you mentioned on third party software like chrome also, it was originally not working without changes.
sergiuvolda
You can't blame the operating system because it only shows the API that any application can use. Google Chrome and Chromium work after setting them to use Wayland, which shows that there is a problem with SoftMaker Office.
If you are not convined, I have screencast you can view here: https://youtu.be/Q7w9dDbKc0Q. Pay attention to output of sudo libinput debug-events in the left:
From the output above, we can see that the pinch gesture is registered. However, for an unknown reason, SoftMaker Office 2024 does nothing. I'm posting here to seek clarification on why this is happening.
Code: Select all
event5 GESTURE_PINCH_BEGIN +6.553s 2
event5 GESTURE_PINCH_UPDATE +6.561s 2 -3.29/ 0.49 (-3.29/ 0.49 unaccelerated) 1.16 @ 1.39
event5 GESTURE_PINCH_UPDATE 2 +6.568s 2 -2.80/ 0.66 (-2.80/ 0.66 unaccelerated) 1.22 @ 1.21
event5 GESTURE_PINCH_UPDATE 3 +6.575s 2 -2.96/ 1.48 (-2.96/ 1.48 unaccelerated) 1.29 @ 1.20
event5 GESTURE_PINCH_UPDATE 4 +6.581s 2 -1.32/ 0.99 (-1.32/ 0.99 unaccelerated) 1.33 @ 0.61
event5 GESTURE_PINCH_UPDATE 5 +6.590s 2 -0.99/ 1.64 (-0.99/ 1.64 unaccelerated) 1.36 @ 0.48
event5 GESTURE_PINCH_UPDATE 6 +6.596s 2 -0.82/ 1.97 (-0.82/ 1.97 unaccelerated) 1.39 @ 0.38
event5 GESTURE_PINCH_UPDATE 7 +6.603s 2 -0.49/ 1.64 (-0.49/ 1.64 unaccelerated) 1.41 @ 0.36
event5 GESTURE_PINCH_UPDATE 8 +6.610s 2 -0.33/ 1.32 (-0.33/ 1.32 unaccelerated) 1.42 @ 0.14
event5 GESTURE_PINCH_UPDATE 9 +6.617s 2 -0.16/ 1.32 (-0.16/ 1.32 unaccelerated) 1.44 @ 0.19
event5 GESTURE_PINCH_UPDATE 10 +6.624s 2 -0.33/ 1.15 (-0.33/ 1.15 unaccelerated) 1.45 @ 0.28
event5 GESTURE_PINCH_UPDATE 11 +6.631s 2 0.00/ 0.32 ( 0.00/ 0.33 unaccelerated) 1.47 @ 0.26
event5 GESTURE_PINCH_UPDATE 12 +6.638s 2 0.00/ 0.12 ( 0.00/ 0.16 unaccelerated) 1.49 @ 0.37
event5 GESTURE_PINCH_UPDATE 13 +6.645s 2 0.12/-0.24 ( 0.16/-0.33 unaccelerated) 1.50 @ 0.30
event5 GESTURE_PINCH_UPDATE 14 +6.652s 2 0.48/-0.97 ( 0.49/-0.99 unaccelerated) 1.52 @ 0.36
event5 GESTURE_PINCH_UPDATE 15 +6.659s 2 0.33/-1.32 ( 0.33/-1.32 unaccelerated) 1.55 @ 0.38
event5 GESTURE_PINCH_UPDATE 16 +6.667s 2 0.16/-0.99 ( 0.16/-0.99 unaccelerated) 1.56 @ 0.30
event5 GESTURE_PINCH_UPDATE 17 +6.673s 2 0.33/-0.82 ( 0.33/-0.82 unaccelerated) 1.57 @ 0.29
event5 GESTURE_PINCH_UPDATE 18 +6.680s 2 0.33/-0.49 ( 0.33/-0.49 unaccelerated) 1.59 @ 0.19
event5 GESTURE_PINCH_UPDATE 19 +6.687s 2 0.16/-0.32 ( 0.16/-0.33 unaccelerated) 1.60 @ 0.13
event5 GESTURE_PINCH_UPDATE 20 +6.695s 2 0.29/-0.14 ( 0.33/-0.16 unaccelerated) 1.60 @ 0.14
event5 GESTURE_PINCH_UPDATE 21 +6.702s 2 0.14/-0.29 ( 0.16/-0.33 unaccelerated) 1.61 @ 0.09
event5 GESTURE_PINCH_UPDATE 22 +6.709s 2 0.00/ 0.12 ( 0.00/ 0.16 unaccelerated) 1.62 @ 0.05
event5 GESTURE_PINCH_UPDATE 23 +6.716s 2 0.12/ 0.24 ( 0.16/ 0.33 unaccelerated) 1.62 @ 0.08
event5 GESTURE_PINCH_UPDATE 24 +6.723s 2 0.14/ 0.28 ( 0.16/ 0.33 unaccelerated) 1.63 @ 0.08
event5 GESTURE_PINCH_UPDATE 25 +6.730s 2 -0.16/ 0.48 (-0.16/ 0.49 unaccelerated) 1.64 @ 0.21
event5 GESTURE_PINCH_UPDATE 26 +6.737s 2 0.00/ 0.49 ( 0.00/ 0.49 unaccelerated) 1.64 @ 0.06
event5 GESTURE_PINCH_UPDATE 27 +6.744s 2 0.00/ 0.99 ( 0.00/ 0.99 unaccelerated) 1.66 @ 0.16
event5 GESTURE_PINCH_UPDATE 28 +6.752s 2 0.00/ 0.99 ( 0.00/ 0.99 unaccelerated) 1.67 @ 0.16
event5 GESTURE_PINCH_UPDATE 29 +6.758s 2 -0.33/ 1.32 (-0.33/ 1.32 unaccelerated) 1.68 @ 0.30
event5 GESTURE_PINCH_UPDATE 30 +6.765s 2 -0.33/ 1.15 (-0.33/ 1.15 unaccelerated) 1.70 @ 0.18
event5 GESTURE_PINCH_UPDATE 31 +6.772s 2 0.00/ 0.66 ( 0.00/ 0.66 unaccelerated) 1.71 @ 0.26
event5 GESTURE_PINCH_UPDATE 32 +6.780s 2 0.00/ 0.15 ( 0.00/ 0.16 unaccelerated) 1.73 @ 0.28
event5 GESTURE_PINCH_UPDATE 33 +6.786s 2 0.00/ 0.00 ( 0.00/ 0.00 unaccelerated) 1.74 @ 0.13
event5 GESTURE_PINCH_UPDATE 34 +6.793s 2 -0.11/ 0.32 (-0.16/ 0.49 unaccelerated) 1.74 @ 0.05
event5 GESTURE_PINCH_END +6.807s 2
Thank you for providing additional details about your issue. However, I’m unable to reproduce the problem with Fedora Workstation 42 environment—touchpad gestures are functioning as expected here.
For your reference, I’ve attached a screen recording demonstrating normal gesture behavior:
