Change Tracking hangs
seasoned_geek
Post by seasoned_geek »
Noticed this on Windows 10 with professional TextMaker 2021. I'm reviewing changes from an editor. If I have to pull open a browser, or look at an email because someone called, etc. causing TextMaker to not be the top level full screen window for 5-10 minutes, it's hung when I get back to it. I can right click the TextMaker icon in the bottom Windows bar and choose close. I get prompted to save the current document just fine, but there is no place I can click in the editor window to bring that window back to life. It's just refusing all input.
Re: Change Tracking hangs
Thank you for reporting this issue. Are you getting this problem with a specific file or with all the files?
Please share the sample problematic file so that we can check it at our end.
seasoned_geek
SuperTech wrote: Mon Jun 16, 2025 9:32 pm Thank you for reporting this issue. Are you getting this problem with a specific file or with all the files?
I'm only working on one file now. A book very close to being published.
To better assist you with this issue, we'll need access to the file. Without reviewing the specific file, we're unable to properly diagnose or troubleshoot the problem you're experiencing.
SuperTech wrote: Mon Jun 16, 2025 9:32 pm Please share the sample problematic file so that we can check it at our end.
seasoned_geek
It was sent
Thank you for sharing your file with us. While we were unable to reproduce the issue in our testing environment, we suspect it may be related to either:
1. Graphics card outdated/ compatibility, or
2. Security software interference
To help resolve this, we recommend the following steps:
1. Update your graphics card driver to the latest version
2. Temporarily disable security software to check for conflicts
3. Test the file in our latest TextMaker 2024/NX (trial version available on our website)
seasoned_geek
I filed the bug report but wish to keep things together.
TextMaker 2024 has the same problem. I installed it on a Windows 10 machine after uninstalling 2021
Problem seems to happen if either Vivaldi or Brave browsers are open during the "idle" time. You guys aren't using any Google code, are you?
Btw, I'm working on a totally different file. This is not a problem with any particular document.
Is it happening when you are using other browsers like Google Chrome or Firefox etc. also?
