Unable to open file
caspar4
Unable to open file
Post by caspar4 »
Textmaker rev. 51224.0308
On one system, I updated from Windows 23 H2 to Windows 24 H2. Now when I try to open file in Textmaker, I get "Unable to open file."
Thanks,
Johanna
caspar4
Reinstal Textmaker 2024
Post by caspar4 »
"Unable to open file." I opened a case two days ago and still haven't had a reply: how to reinstall?
Re: Reinstal Textmaker 2024
Thank you for reporting the issue. Please follow these steps:
  1. Open “Add or Remove Programs” in Windows
  2. Search for SoftMaker Office and uninstall it
  3. Restart your system
  4. Download the latest version from our website and reinstall it
Let us know if you need further assistance.
caspar4
Re: Unable to open file
Post by caspar4 »
Hi Supertech:
Thanks for reply. However, my product key did not work with the .msi download you provided.
I have 12/18/23 upgrade to Softmaker Office Pro 2024 product key. The version you provided did install but will expire in 30 days.
I entered product key for Softmaker Office Pro 2024 and got message "Please enter product key for current product (Softmaker NX).
Thanks, Harmonia
Thank you for trying the steps. So, are you able to open your files now?
On the same page which I provided, there is link for SoftMaker Office 2024 also. You can click here.
For your reference:
caspar4
Post by caspar4 »
Supertech,
I can open files now but only for 30 days. I'm glad to see that the 2nd .msi file is different from the first. That might work.
I'll let you know.
Harmonia
