How to delete a hyperlink
IMAZTriBabe
Post by IMAZTriBabe »
I downloaded the 2024 SoftMaker NX for Windows, 64bit, a few days ago. It Installed just fine. When I update content on an existing PlanMaker document, when adding my email address, it creates a hyperlink. When I go to the tool bar, under Contents, the option for "remove hyperlink" is grayed out. i do not have access to that option. How can I make that option, selectable?
Thank you in advance...
Lori
Re: How to delete a hyperlink
Thank you for reporting this issue. I haven't been able to reproduce the problem on my end. Could you please confirm if you're seeing a hand icon when hovering over the email address? To help investigate further, please share a screenshot and the relevant file.
IMAZTriBabe
that will be hard to do.... it is part of a planmaker book that has all my passwords and logins... it happens when I put an email address in the box, for a given web site, that I have created a log in for.. hope that explains it..I simply type my email and it automatically turns into a hyperlink.. When I go to the tool bar, under "Contents", the option for "remove hyperlink" is grayed out. I do not have access to that option. I just need to know where the setting is, to "turn off automatic hyper-link"..
stascheit
Post by stascheit »
When you use the Ribbon interface:
Try this command: On the Ribbon tab Insert | group Links | Hyperlink.
Then a dialog box opens, here you can delete/edit your Hyperlink.
When you want to use Home | group Contents | Delete >> Remove link, I think it's necessary to put in front a "mailto:", when you type your email directly in a cell.
For example: mailto:misterx@example.com
Then the Remove link command is available too.
