Pop Up gets in the way
mistrowl
Post by mistrowl »
How do I get this to go away?
I get the need for popups, as annoying as they are... but this one is actually interfering with my workflow and appears every time I open a file.
lgsl
Re: Pop Up gets in the way
Post by lgsl »
Is what happens when you use FreeOffice.
Léon
Post by Léon »
If you click on the white square on the top left, next to the 'i', it goes away (as long as you stay in the same document, I think).
Return to “FreeOffice PlanMaker 2024 for Windows”
