File Format
dixierebel
File Format
Post by dixierebel »
When I save a doc, I select docx as the file format. The docs are all being saved as both .bak and .docx. What do I need to do to save only as .docx? Thank you.
Re: File Format
Post by Jossi »
The .bak files are automatic backup files. Go to Tools > Options..., tab "Backup", and uncheck "Keep older versions of the document" to stop saving them.
4work2test
Re: File Format
Post by 4work2test »
Is it possible to disable this function (backup) during the installation stage or disable it immediately for all users of the computer?
Re: File Format
No, backup is an important feature to prevent data loss, so it shouldn't be deactivated during installation.
Return to “FreeOffice TextMaker 2024 for Mac”
