Textmaker doesn't switch to italic font for Cyrillic texts
NX-01
Post by NX-01 »
In principle I don't use italic versions of fonts for my personal documents but lawyers and legal services do use it and that's how I noticed that the "I" button doesn't work properly. I could write a long explanation about the problem but I think visual explanation works the best, so here's one. Also note that this problem only occurs with Cyrillic alphabet. Latin works fine.
https://www.mediafire.com/file/4digqk2p ... m.mkv/file
(the video is raw format, meaning that I haven't converted it. It was recorded using simplescreenrecorder, so if it doesn't run for you, you'll have to convert it using whatever codec you have installed)
As a workaround for this problem I had to find and download a font named "times new roman italic.ttf" and select that font when I want the text to be italic. I have all MS fonts installed and MS Office (ran with Wine 10.5) properly turns "Times New Roman" into italic when the button for italic is pressed (without selecting the workaround font). Only FreeOffice doesn't do that. That makes me believe the problem is in FO, not in the fonts themselves.
The video also shows that the workaround works but not the traditional way.
FO is installed from AUR but the source trizen uses to install it is from your website: http://www.softmaker.net/down/softmaker ... -amd64.tgz
lgsl
Re: Textmaker doesn't switch to italic font for Cyrillic texts
Post by lgsl »
This is not a FreeOffice issue but a Font issue.
You are assuming that FreeOffice is aware of you having MS Office installed in a wine bottle and it is reading/indexing fonts from there, this is not the case. If you want to use Times New Roman on non-wine envirolments then you must install/copy the fonts in the right place, like ~/.fonts. (Check the arch wiki for details)
Also consider that MS Office forces/distorts fonts when it needs to in order to get a bold or italic effect even when the glyphs are not present in the font itself. This is an awful practice that Softmaker do not replicate.
lgsl wrote: Wed May 14, 2025 2:30 am Also consider that MS Office forces/distorts fonts when it needs to in order to get a bold or italic effect even when the glyphs are not present in the font itself. This is an awful practice that Softmaker do not replicate.
Computer-generated italics are ugly, but they are commonplace. TextMaker does do this -- I just tested it using a sample document and several fonts on my computer that I verified do not have separate TTF files installed for italics. It works in TextMaker exactly the same as it works in MS Word and LibreOffice Writer -- or even WordPad.
However -- I tested under Windows 10. I don't currently have a computer set up to run Linux.
Return to “FreeOffice TextMaker 2024 for Linux”
