Font Size Issue with Tables in PlanMaker.
oasecho84
Post by oasecho84 »
Hi everyone,
I'm experiencing an issue with font sizes within tables in PlanMaker. When I create a table and try to adjust the font size, the changes don't seem to be applied consistently. Sometimes the font size remains the same regardless of what I select, and other times it only applies to a portion of the text within the table cell.
Has anyone else encountered this problem? Is there a specific setting or workaround I should be aware of? I've tried different font types and sizes, as well as restarting the application, but the issue persists.
Any help or suggestions would be greatly appreciated!
Re: Font Size Issue with Tables in PlanMaker.
Thank you for posting your problem, but we are unable to reproduce it.
Are you facing this issue with any specific file or with all the files? Please share the file with a screen recording of the issue.
I don't understand the question or the problem. PlanMaker is a spreadsheet -- every worksheet is a gigantic table. I do not see any way in my PlanMaker to create a table. Are you asking about tables created in TextMaker?
You can create tables in PlanMaker also of selected range from ribbon command Insert | Table.
Wow!
I used Excel for 20+ years before discovering SoftMaker Office, and I had never heard of this. I guess if Excel offers it, PlanMaker has to support it but (like so much from Microsoft) it seems rather idiotic.
