re-sorting - organizing - a scanned document
RMerchant
Post by RMerchant »
I have documents which have been scanned in two batches - double sided originals but I don't have a duplex scanner so I have fronts and backs. I now need to reorganize the pages in numerical order.
Can anyone offer me an algorithm for this? In acrobat I use the thumbnail pane in which I can drag pages to the correct location but I can't make this work in FlexiPDF as I cannot resize the thumbnails to see more than one image on the screen.... On the main viewer window I can resize but I don't seem to be able to drag and drop pages.
Any help is appreciated. This is a pretty common scenario for me.
Thanks RIchard
Re: re-sorting - organizing - a scanned document
Thank you for your inquiry. In FlexiPDF, you can indeed resize thumbnail windows and rearrange pages via drag-and-drop functionality. Please refer to the attached screen recording for a demonstration of these features.
RMerchant
Post by RMerchant »
Thank you for your response here. I see what you are doing, and I can mimic that on my system.
Is there any way to manually resize the thumbnails so as to get many more on the screen? For example I might have a 25 page document, double sided, which scans to 50 pages, with the order reversed. I want to see rows with five pages per row (or five 'columns') and be able to drag Page 26 (or potentially page 50) into the page 2 position. Having all the pages in one column will not make that process easy.
Regards
Richard
RMerchant wrote: Thu May 29, 2025 10:17 pm Is there any way to manually resize the thumbnails so as to get many more on the screen?
No, that's not possible.
RMerchant
Post by RMerchant »
Thank you for your reply.
It is very unfortunate that re-sizing thumbnails manually is not possible. This is a significant limitation of the product.
I would suggest that this be referred to the development team for implemenation.
Richard
I have forwarded this as an improvement suggestion.
