Paste Text Only
dixierebel
Paste Text Only
How do we paste text only, no formatting?
raitis.veksejs
Re: Paste Text Only
To paste text only you should use ribbon Home command Paste>Paste unformatted text. Another option is to use shortcut key Alt+Ctrl+V for paste special dialogue where you can select to paste unformatted text.
dixierebel
Re: Paste Text Only
Thank you. There are no alt and ctrl keys on a Mac.
Re: Paste Text Only
Well, my Apple keyboard has an alt as well as a ctrl key.
raitis.veksejs
Re: Paste Text Only
The Alt key on the Mac is also called Option and you can find it next to the Command key.
Elizabeth zhang
Re: Paste Text Only
Great feature! I use it every day, especially when transferring text from the internet to documents.
Elizabeth zhang
Re: Paste Text Only
Thank you for the help! I didn't know such a keyboard shortcut existed. Now I can paste text without formatting more easily.
Elizabeth zhang
Re: Paste Text Only
On Mac, I use the Command+Shift+V shortcut to paste without formatting. Maybe it's worth adding this to the instructions?
