Merge Document Feature Request
KJBurton
Post by KJBurton »
Having managed to create a simple mail merge document, the only options are to save the document or print the merged document.
I would like to an option to "Edit Individual Documents and to "Save the Merged Document". Unless i'm missing something, I am unable to do this. Yes I can print the document to pdf but this is not suitable for editing. Saving the entire merged document to docx for example would allow me to peruse the document and make any alterations and personalisation for a specific recipient. I can then either print the entire document or export to a pdf for printing later.
Thank you
Kevin
Re: Merge Document Feature Request
I have forwarded this improvement suggestion.
