[feature request] - sub bullets hierarchy via tab key
npferreira
When inserting bullets, if I want a 2nd level hierarchy bullet - aka sub-bullet - allow to do this via tab key.
Re: [feature request] - sub bullets hierarchy via tab key
You can assign shortcut keys by yourself.
Choose the command File | Customize >> Customize ribbon (or just double-click at a free space on the ribbon).
The dialog box shown below will be opened.
Type "list level" into the Quick search field to find the relevant commands.
Press the desired shortcut into the Shortcut keys field for each command and press Add for each.
Press Close to finish.
npferreira
