Excel file column width non respected - Bug detected
giulio
Post by giulio »
When opening a file the column width is not correctly shown and when saved as .xlsx file the column width is changed to an other value
Re: Excel file column width non respected - Bug detected
Thank you for reporting this issue. To help us investigate further, could you please share:
1. The affected file
2. A screenshot showing the problem
This allows us to reproduce the issue and work on a solution for you.
Return to “PlanMaker NX for Android”
