Font install
giulio
Font install
Post by giulio »
Hello, I already saw somewhere it's possible to install fonts so that I can use the same ones on Windows.
I have OTF and TT (Truetype) fonts that I use on Windows and that i wish to use also on Android. How can I install them so that they are used in all the Softmaker Office apps ?
albertdelaney
Re: Font install
Post by albertdelaney »
Just paste them into the fonts folder. That's what I did.
giulio
Re: Font install
Post by giulio »
thank you where is the font folder? I suggest to add an import feature directly into the app where fonts can enabled disabled.
Are OTF font supported or only TTF ?
Re: Font install
Please paste your font file to folder /SoftMaker/Fonts/.
ITFlip
Re: Font install
Post by ITFlip »
Hello,
Both OTF and TTF fonts are supported.
Font files for additional fonts should be placed in the folder: /SoftMaker/fonts/
Fonts placed in this folder will be available to all Softmaker Office apps.
Depending on the file manager used, the location of the folder might appear in Internal Storage as:
/storage/emulated/0/Softmaker/fonts
To modify which fonts are displayed in lists for Softmaker Office apps, go to the File tab, choose Options, then Fonts.
Here you can uncheck fonts that you do not want displayed in lists in the apps.
Unchecking a font does not uninstall it.
A change made in one Softmaker app will affect the list of displayed fonts in all Softmaker Office apps.
giulio
Re: Font install
Post by giulio »
Hi, thank you, I suggest to add an import/install feature to install the fonts
