Two instances of PlanMaker file
hkbs
Post by hkbs »
Is it possible to open two instances of my PlanMaker file? It has several tabs and
I would like to view two tabs at the same time.
Re: Two instances of PlanMaker file
No, it's not possible, but you can make a temporary copy of it and then open both files.
hkbs
Post by hkbs »
Yes, I have tried that but it would be much better to have 2 instances as in Excel. Couldn’t it be added to PlanMaker?
You can drag the tab to the desktop to make a separate window instead of tab, then place the two windows side by side, but it will still be two copies of the file.
