Top align not available
mistrowl
Post by mistrowl »
I'm trying to find a way to top-align text in a cell, but I have no vertical alignment options.
I have left, right, center, and justify, but no top, middle, bottom alignment buttons.
Where can they be found?
Thanks!
Re: Top align not available
Right click the selected cell or cells. From the pop-up menu choose "Cells" Then choose the "Alignment" tab, and you can set both vertical and horizontal alignment.
mistrowl
Post by mistrowl »
Yeaaaahhh I'm aware that's an option, but it's horribly inefficient. I've seen screenshots from SoftMaker's own documentation:
That says there should be a button. Is their documentation incorrect?
The documentation describes the ribbon user interface, but you use menus and toolbars.
You can customize the toolbars to add vertical alignment, or you can switch over to the ribbon UI.
mistrowl
Post by mistrowl »
Ah ha! Yes! Switching to Ribbon worked.
Thank you!
martin-k wrote: Fri Feb 28, 2025 6:14 pm The documentation describes the ribbon user interface, but you use menus and toolbars.
Thank you for this. I still use "classic" menus, and I had not realized that I can customize them. This is much appreciated.
