Auto Full stop
Bri
Auto Full stop
Post by Bri »
If I type a letter then space, I get an automatic full stop (end of sentence) added. Can't see how to stop this.
Re: Auto Full stop
Have you reviewed all the autocorrect settings?
Bri
Re: Auto Full stop
Post by Bri »
Yes but couldn't see one that fits
Re: Auto Full stop
I just tested it on two different Samsung Android tablets, and I couldn't replicate the problem.
lgsl
Re: Auto Full stop
Post by lgsl »
If you are using a virtual keyboard, this is probably the one doing the change. Check the settings of whatever keyboard you use, just to make sure. With some there is an option to prevent the keyboard ofdoign this, with other you need to turn off autocorrect.
Return to “TextMaker NX for Android”
