Combining multiple files into one document
I have a series of one-page reports in PDF. They need to be combined or assembled into a single PDF for each month. With Adobe Acrobat this was easy -- open the first document, select the rest, and they would be combined in a single operation.
I have FlexiPDF 2022. It does not appear to be possible to do this in FlexiPDF 2022. There are two ways to insert a single page at a time, but it doesn't appear possible to import or combine all of them in a single operation. Doing it one page at a time is a tremendous waste of time.
Is this possible in FlexiPDF 2025?
stascheit
Re: Combining multiple files into one document
Post by stascheit »
Yes, you can use the "Join" command:
Document | group Edit | Join
This command already exists in FlexiPDF 2022.
