Manually setting the Y-axis in Radar Graph
L.L.Rye
Post by L.L.Rye »
I've been looking everywhere, and I cannot for the life of me find the function for this. Maybe it's just me.
To explain; I want to make a series of separate radar graphs, and I want the y-axis to be consistent between them; but when I select the area I want to represent, it naturally sets the y-axis to whatever 'makes sense' for the values. So if, on some of the graphs, the highest value is 80, it goes from 1-100, which is what I want.
But if the next graph has 55 as the highest number, it automatically sets the scale from 1-60, and I simply can't find the option to change that. Does anyone have any ideas? If nothing else, then about where to look in the manual? Because I just can't see it.
If anyone has the answer, thank you so much in advance!
Re: Manually setting the Y-axis in Radar Graph
Please share your PlanMaker file with screenshot and some details of the problem for better understanding.
Return to “FreeOffice PlanMaker 2024 for Windows”
