Feature updates are priceless but beneficial!
SPM2025
Post by SPM2025 »
Sorry dev, Straight to the point, When I have arranged the item eg shape perfectly, I need to add an animation from the original position to a final position where the item should be. If I can combine the existing animation, sorry I forgot to maybe "fade" at the beginning with the "custom animation" animation. This feature has been around for a long time but I haven't been able to try it for free for a while. I know this feature requires adding code to the script without requiring capital so consider bringing a big change to the slide. As you know ai can help this update, just a suggestion. I am very needy and take things seriously and hope you are too.
That's all, I hope you respond even if you have to refuse.😊
Re: Feature updates are priceless but beneficial!
I have forwarded this improvement suggestion…
SPM2025
Post by SPM2025 »
Thank you, ❤️
Note: Edited by admin as this is an English-only forum.
Return to “Presentations NX for Android”
