Network paths
oblivion
Network paths
Post by oblivion »
Are there any plans to support opening files based on UNCs? At present, I get "path not found" errors if I try.
(Note that this is with the portable version, in case that makes a difference.)
Re: Network paths
Thank you for sharing the issue you're experiencing. To assist you better, could you please provide a screenshot of the error and the steps you took to reproduce it?
Additionally, is this issue occurring with all three applications, or is it specific to one? It would also be helpful to check if the path in question works with other software (non-SoftMaker applications).
