How do I set the default zoom to 100%?
rusman
Post by rusman »
When I open documents in TextMaker, they always open with a 200% zoom or a random zoom level. Additionally, it sometimes opens in split-screen mode, which I don't like. I prefer to view only one page.
In MS Word, I used to click the View tab and select One Page and set the zoom to 100%, so it was fixed to display one page at 100% zoom. However, in TextMaker, the settings seem to be different.
How can I achieve the same setup in TextMaker?
Thanks!
ref: https://imgur.com/QspTRsO
Re: How do I set the default zoom to 100%?
Post by Jossi »
In TextMaker, existing documents are opened with the zoom level they were saved with. If you want all your new documents to have a 100% zoom level, open the template Normal.tmvx, set the zoom level to 100% and save the template again.
