graphix on mailing labels
Princy557
Post by Princy557 »
HI,
Long time ago I requested, suggested, thought was a good idea. The ability to be able to add graphics to labels, tables and lists.
Did anything happen about this?
Adding to that now would be the ability to add an barcode/ QR code/ addresscode.?
Regards
Princy557
Regards
Princy557
Re: graphix on mailing labels
I have again forwarded this improvement suggestion for labels.
You can insert embedded graphics/barcode/ QR code etc. into tables or lists but make sure these are not frames.
